Home > In Car Electronics > Dodgy front screen on DVD only |
Tom Davison Member Since: 19 Oct 2022 Location: Norfolk Posts: 15 |
Hi all,
Fri Oct 28 2022 4:37pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4858 |
I am only going from memory, but I seem to vaguely remember you can change the picture aspect ratio in a menu somewhere and see if it makes any difference, not a audio/video engineer so could be completely off the mark. I could however be getting completely confused with something else and at my age that's not difficult. I do have factory RSE and will have a look to see if there is a menu in there when I have chance.
Fri Oct 28 2022 10:40pm |
Not quite sir, it's obviously impossible to tell from a photo now I think about it, but the front screen flickers, so it shows a band at the bottom of something random (in the photo's case the top menu of the DVD) but flickers erratically, as in it shouldn't be showing it.
Mon Oct 31 2022 11:54am |
Do you know if it is a aftermarket system or factory fit one?, if it is a aftermarket system it may not be connected to the most fibre optic cable system as some were done via a transmitter module of sorts I believe. What happens with the front screen when playing a DVD without the rear screens media playing, does it still flicker?.
Mon Oct 31 2022 9:48pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4801 |
Do you have TV module and does the front screen break up the same on TV ? |
Tue Nov 01 2022 6:36pm |
Hi everyone, thanks for the replies:
Wed Nov 02 2022 9:26am |
Only a wild suggestion, but is the video format set to PAL or NTSC and correct region?, not sure what difference it would make to video if any or set to NTSC as I think UK would be PAL or if you can even change it anywhere in the system. As say only a suggestion.
Wed Nov 02 2022 10:01pm |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 |
The PAL/NTSC setting works on all screens simultaneously. Setting to NTSC would render the picture illegible on all of them anyway. Wrong region would just not play throwing an error message.
Thu Nov 03 2022 9:28am |
So on a 2010 car is the player in the IAM just a CD player or a DVD player as well as a dvd multi changer player in the boot.
Thu Nov 03 2022 11:09am |
Mine does not accept DVDs.
Where is it, this VIN decoder? Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
Thu Nov 03 2022 1:29pm |
I thought the connector on the rear of the display was a 6 pin idc header
Thu Nov 03 2022 6:59pm |
I'm not sure, but the guide to retrofit RSE to a Disco details the connections quite accurately: https://media.disco3.co.uk/gallery/albums/...0Guide.pdf Regards etc.,
Thu Nov 03 2022 7:16pm |
That’s the older (pre facelift) screen |
Thu Nov 03 2022 7:30pm |
Since the later cars share the same part numbers I am 51% sure it works exactly the same. Regards etc.,
Thu Nov 03 2022 11:00pm |
