![]() | Home > General (L461) > EV Cost, Range and software issues |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1897 ![]() ![]() |
It took me a while to get my P400e scheduling to work, if the Pivo Pro system is similar to the InControl then I had to set it up in the car.
Milky400 Member Since: 11 Aug 2022 Location: cambridge Posts: 92 ![]() ![]() |
Yep set in car computer and it defaults back to direct charge, when you look back into the menu it still showing scheduled. |
The P400e has the same 2 schedules that need setting but that doesn’t activate it.
Just had JLR tech out and the charging issues are known and a patch was uploaded which solved the initial issue, however if I have it plugged in I can now lock it with the key, however if I unlock it it starts to charge. So halfway there I guess. |
That's progress I guess ! |
FFS JLR, over the air software update and boom cannot now schedule charge. I’m starting to get very annoyed.
Have you updated the Remote app? The latest version is to fix an initialising issue.
Yes updated. It’s not app related as it doesn’t start (flash blue) when plugged in. |
You are starting to put me off the cancelled build slot that I have been offered ! |
It’s an awesome car, but i I bought it to be used primarily as a EV for daily stuff, and if this continues it will be going back and I’ll be leaving the brand as this was the last chance…. It’s not as though the EV tech is new, it’s lifted from the previous models. |
My P400e had lots of similar problems when I first had it but seems to have settled down now.
So how much of a t**t do I feel.
Well it's understandable, any seasoned Land Rover owner is always expecting something to go wrong! |
Yes guess it is expected 😂 I have little faith in there products.
