![]() | Home > Maintenance & Modifications > Screen wipers - refer no? |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
Some references say 1x22" and 1x21" for the front, but like many others I've always used 2x22" with no problems. 16" for the rear. As for a good manufacturer, I always fit Bosch. Barrie.
Nilrem280 Member Since: 02 Jun 2020 Location: Portchester Posts: 84 ![]() ![]() ![]() |
Bosch Aerotwin set for the front is AR550S & H403 is for the rear. |
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 346 ![]() ![]() ![]() |
Many thanks Nilfem - I had been wading through all the possibilities on the French net. Found the ones you suggest on Amazon Fr and order the set. Thanks again! Andrew Kennedy |
