Home > Technical > Warning light woes!
Gas-guzzler
United Kingdom 2007 Range Rover Sport TDV8 Sumatra Black
Warning light woes!
Hi guys,
Started the car this morning and I have a whole load of caution lights on the instruments. Air suspension has dropped down to low and won’t raise, HDC is saying not available and a park brake fault. Don’t worry about the engine management light, that’s been on for ages and is an EGR fault that is a side issue. Any thoughts gratefully received?
Post #627276 Tue Oct 11 2022 3:55pm
Stevepd
Battery in good condition?. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #627277 Tue Oct 11 2022 3:58pm
Gas-guzzler
Battery seems ok. I’d read that a bad battery can cause these symptoms so gave it a full charge and same lights still come on. I’ll get a battery health check done to see. Thanks for the suggestion.
Could a brake wear sensor or faulty ABS sensor cause these issues?
Thanks
Post #627278 Tue Oct 11 2022 4:15pm
Gas-guzzler
Following a bit of research I’ve decided to order a brake light switch as it’s a cheap fix stating point. The brake lights do work as they should and the EPB releases with the button when I press the brake pedal, also, I can hear the solenoid click to enable to auto gear-shift to move out of park and neutral but thought it worth a shot.
Also, the transfer switch from Hi to Low gear ratio works so I guess the transfer module is ok? I’ll report back when I’ve fitted the new switch.
Thanks.
Post #627300 Tue Oct 11 2022 10:26pm
NoExpert
This is where you want to get the actual codes read instead of playing parts roulette. And just cause the engine fault has an old EGR code doesn’t mean new codes haven’t been added. That’s the problem with ignoring those kind of lights. Get the codes, do some diagnostics, then spend money on parts. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #627304 Wed Oct 12 2022 5:16am
Agreed. You need a proper code read done. Trying to second guess it is going to waste time and money. 2012 SDV6 - it's missing a couple of cylinders
Post #627315 Wed Oct 12 2022 11:37am
karlos01
get the codes read as it could be anything one sensor could be causing the others to play up
Post #627318 Wed Oct 12 2022 12:06pm
aaronjb
Agreed with the above - I've been here and got that T-shirt (as has everyone else, probably!)
I had a christmas tree of lights caused by CAN-bus failures and changed (in order of expense!):
The brake switch (which achieved nothing)
The whole engine ECU (because it looked like it had failed internal voltage regulation) which achieved nothing at a cost of £600
I was pretty close to sending the cluster off for repair as well..
Eventually I took it to a specialist.. one replacement fuel pump (incidental failure) and a wiring fault under the fuse box located and the problem was solved. Even including the labour to diagnose and the fuel pump it would have cost less than I'd spent so far "fault finding"! 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #627323 Wed Oct 12 2022 2:16pm
Gas-guzzler
That’s all great advice. Thanks guys. So, I’ve bought an Autel AP200 diagnostic tool and it’s shown a left rear wheel speed sensor which I’ve ordered from euro car parts. Hopefully be fitting it tomorrow. I’ll post here results. Thanks again.
Post #627368 Fri Oct 14 2022 10:06am
karlos01
had same problem with mine abs sensor is easy to replace only a 10mm nut holding it in place
Post #627371 Fri Oct 14 2022 12:00pm
Gas-guzzler
Thanks Karlos and to all who helped. Problem solved. I bought an Autel AP200 diagnostic tool which identified a fault with the rear left wheel speed sensor. Replaced that and all lights are now extinguished and car drives fine. Thanks again folks. Thumbs Up
Post #627428 Tue Oct 18 2022 1:31am
Stevepd
Excellent thanks for posting the fix Thumbs Up 2006 2.7 TDV6 HSE in Cairns Blue.
Post #627433 Tue Oct 18 2022 7:25am
karlos01
glad it sorted out for you
Post #627450 Tue Oct 18 2022 6:24pm
