| RRSPORT.CO.UK | ||
|  | Home > Technical > High speed vibration help please? |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | Seized EPB shoes or rear caliper/s | ||
|  Thu Oct 06 2022 9:52am |
| Gas-guzzler Member Since: 28 Dec 2021 Location: Paisley Posts: 64      | Thanks for the reply. That’s very interesting as I have changed the rear shoes and pads just recently. The shoes were pretty rough against the backing plate but cleaned and lubed everything up. I wonder if I’ve put something back together incorrectly?
|  Tue Oct 11 2022 3:48pm |
| NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 522      | Can also be worn control arm bushings. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
|  Tue Oct 11 2022 5:24pm |
| Gas-guzzler Member Since: 28 Dec 2021 Location: Paisley Posts: 64      | Thank you. I’ll do some investigation over the next few days and post my findings.. | ||
|  Tue Oct 11 2022 7:03pm |
| Crraigymmmmm Member Since: 06 May 2021 Location: Peterborough Posts: 163      |
 Second this, was for me anyway! Sorted with Poly bushes | ||
|  Wed Oct 12 2022 8:09am |
| NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 522      | Most common bushings are front end lower arm rear bushings and rear end upper arm front bushings. This doesn’t mean nothing else will be bad, but they’re the typical culprits. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
|  Wed Oct 12 2022 9:26am |
| Gas-guzzler Member Since: 28 Dec 2021 Location: Paisley Posts: 64      | Thanks guys, your input is much appreciated. I think I can rule out the rear brakes. The shoes nor the pads seem to be binding as the car rolls freely on an incline and no excessive heat build up on the disks when driven. I’ll check the aforementioned bushes. | ||
|  Mon Oct 24 2022 5:11pm |
| Posting Rules
