Home > Technical > SDV6 3.0 engine reliability
portculisrrs
As someone seriously looking into the purchase of a used RRS (around 2015/2016), I am looking into the background of the 3.0 V6 engine failures (engine crank shaft failure). Can anyone with some knowledge of these failures fill me in on a couple of questions
- how common is it, is it more specific to either the TDV6 or the SDV6 and are there specific model years in which the problem was more apparent.
- is there any background into the possible causes (ie I have heard inadequate servicing, incorrect oils, contaminated DPFs etc etc)
- did LR introduce any specific changes to the engine design to counteract the problem
Many thanks for any advice you can share
Anthony
Post #627265 Tue Oct 11 2022 9:42am
Not specific to any year.
How to Avoid isn't known.
No fixes introduced to UK models
Get a good warranty and read the small print
Post #627266 Tue Oct 11 2022 11:00am
Oldandconfused
If you do below average miles a year, have a think about the V6 petrol, I would. That being said, I don't know personally if they have any design weakness. There aren't that many about compared to the diesel, and I haven't read any issues on here.
If you do higher mileage, and longish trips, the DPF should remain clear reducing oil dilution due to frequent/incomplete regens.
A lot of warranty companies will exclude the crank as it's a known manufacturing defect. As has been said, read the small print and get written confirmation of cover.
Good luck.
Post #627268 Tue Oct 11 2022 11:35am
Crs
England 2013 Range Rover Sport Supercharged Autobiography Firenze Red
Had the sam dilemma, in the end I brought the Petrol supercharged, I can’t put up with these DPF , I do more short journeys than long and I have had trouble with DPF on every Diesel I have owned.
Post #627284 Tue Oct 11 2022 5:32pm
