Home > Technical > Screwball knobs on RRS Arm-rests ?
AIJ 615
Gents
What are they and what do they do ?
Post #627006 Sat Oct 01 2022 7:19am
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
Turning them raises or lowers the angle of the arm when it's in the horizontal position. Barrie.
2017-Jan 2024: 2005 RRS 2.7TDV6. Best car I ever had - until now!
Current: 2018 Ford Ranger Wildtrak 3.2
Post #627007 Sat Oct 01 2022 7:40am
AIJ 615
I’m with ya, thanks Barrie
Alan
Post #627009 Sat Oct 01 2022 7:44am
Do you not have a Owners Handbook?
Post #627010 Sat Oct 01 2022 7:56am
AIJ 615
Morning Col
Unfortunately no, I have order one from eBay.
Al
Post #627011 Sat Oct 01 2022 8:04am
As I was never able to find a PDF copy of one so I put one together during Covid lockdown for something to do, although it is for a MY12/13 car there is very little difference to the earlier facelift cars, the infotainment interface is different, also I know the wiper switch/washers work different way round may be a few other bits but nothing much. I'll post a link to it over the weekend if it's any help, also added some bits that are not in the official one like service schedules, check sheets etc.
Post #627012 Sat Oct 01 2022 8:15am
AIJ 615
Cool cheers 👍
I’ve always wanted to know what the changes were from pre facelift to facelift edition.
Post #627021 Sat Oct 01 2022 2:00pm
I was actually referring to the difference between the MY10/11 and MY12/13 facelift variants, easiest way to find that out really is to have a look at a pre-facelift.
Post #627044 Sat Oct 01 2022 9:46pm
NoExpert
I have the 2011 owners handbook in PDF, if you’re interested.
2010/2011 are surprisingly different to 2012/2013. The bulk of it is the infotainment system with MOST 2.1, but there are a couple other characteristics like the rotary shifter and its neutral bypass setup and the one piece electric tailgate. I think the headlights may be slightly different as well.
The other thing to watch for with 2010’s is the rear brakes. They changed the rear calipers for a bit in 2010 then reverted back to the 05-09 rear calipers. Different sliding pins, boots, and brake pads.
And 05-09 RRS’s are very different to 2010-2013 RRS’s. When I was test driving while looking it felt like two completely different cars despite being so similar. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #627046 Sat Oct 01 2022 11:48pm
Thankfully they never fitted that rotary gearshift thing to the S/C, I think it was only fitted with the 8 speed box, the only difference in the headlights was the internal backing changed from grey to black same with the rear lights I believe but not totally sure on that one.
Post #627047 Sun Oct 02 2022 12:07am
NoExpert
It is part of the 8HP70 transmission which was fitted to the 3.0 SDV6 for emissions reasons. We have a 2013 SDV6 with the 8 speed at the shop, talk about screwed if something acts up. Your options are park or neutral, no trying to limp that home. We also have a 3.0 TDV6 with the 6HP28 transmission, same as your SC. It is acting up and locking into park when warm, at least it has a manual override to release the lever though.
Do the 12/13 headlights have the beam flattening adjustment lever inside? I’ve read mixed info on that and that they just come with a flat universal pattern. I was going to check the 2013 at work, but it has a crappy Kahn grill that is way more effort to remove than I feel like putting in just to find out. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #627050 Sun Oct 02 2022 8:10am
No adjustment lever, something to do with beam pattern that nothing needs changing.
Post #627051 Sun Oct 02 2022 8:29am
NoExpert
That’s what I recall, it’s basically just a flat beam pattern like if I were to flip the switch in mine. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #627063 Sun Oct 02 2022 5:02pm
