| RRSPORT.CO.UK | ||
|  | Home > General > Indie unable to replace anti roll bar bushes - what now? |
| Turdmon Member Since: 05 Aug 2020 Location: Lancashire Posts: 150    | Definitely take it somewhere else.
|  Sat Sep 24 2022 9:16pm |
| peterjj Member Since: 15 Mar 2017 Location: Canberra Posts: 49    | Except those roll bar bush clamp bolts are very difficult to get to. Hard enough to get a spanner to them, impossible to get a drill to them. Pete
|  Sun Sep 25 2022 12:34am |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | Two of the bolts you can see the end of the thread from under the car, so on a ramp may not be to bad to drill out but the third one is captive inside a welded cross member so impossible to see captive nut part and drill, however as the thread on that one is not totally exposed to the element might be one that will come out intact, If you remove the front propshaft it may give more access to the passenger side bolt heads to get a better fitting six sided socket and see if they will undo, might also be worth soaking them in penetrating oil for a few day's and take it to someone who has the right special tools to fit the bolts.
|  Sun Sep 25 2022 12:44am |
| Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 784      | Having had both front and rear ARB's replaced on my MY10 3.0ltr I can relate my experience.
|  Sun Sep 25 2022 10:06am |
| Josh95 Member Since: 08 Dec 2021 Location: Belfast Posts: 49      | Thanks, this makes sense. Is it safe to leave the it the way it is then or what should my next steps be? | ||
|  Sun Sep 25 2022 4:20pm |
| Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 784      | If it was my car, I couldn't live with it and would try and find a good indi who will be able to properly assess if they can do the job. Armed with the information gained from here, you can ask a few pointed questions so you are happy they know what they're doing. It may be that you will have to have the body lifted if the worst happens, and it would be worth getting a quote in case so you know how wallet draining it could be.
|  Mon Sep 26 2022 9:03am |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | Try another Indy   | ||
|  Mon Sep 26 2022 6:01pm |
| Posting Rules
