Home > General (L494) > Sensor for DPF - engine removal
John1311
Car was in garage to replace the temp sensor which activates DPF etc to be told they cant remove it and will need to go back to main dealer for the engine to be removed to allow this to be done - I know the implications of not doing this could be a £3k bill for new exhaust system and the sensor would still need to be changed - anyone have any ideas on the cost to do this ? many thanks 2016 Range Rover Sport SDV6 autobiography (MY17)
2017 Range Rover Velar First Edition SDV6
2015 Range Rover Sport Autobiography 4.4
2012 Range Rover Sport SDV6 HSE Luxury Black
Post #626654 Fri Sep 16 2022 9:55am
Presumably the garage it's current in isn't an independent LR specialist - any decent LR specialist ought to be able to remove the engine and do it at a significantly lower cost than a Land Rover main dealer. They'll likely also be able to do it all without causing damage to the car. I'd be very wary about letting a LR main dealer do something as complicated as removing the engine. 2012 SDV6 - it's missing a couple of cylinders
Post #626655 Fri Sep 16 2022 11:12am
John1311
yes its Mike Harding in Bovey Tracey one of the only local indys' to us - so was surprised they wouldn't do it - they have removed the body off a previous sport to do the turbos - so now unsure what to do 2016 Range Rover Sport SDV6 autobiography (MY17)
Post #626657 Fri Sep 16 2022 2:54pm
Red Arrow
Drop Disco Mikey a PM Thumbs Up
Post #626664 Fri Sep 16 2022 4:38pm
John1311
where in the country is he based? 2016 Range Rover Sport SDV6 autobiography (MY17)
Post #626666 Fri Sep 16 2022 7:08pm
Red Arrow
Up here in Dundee , but he has immense knowledge of all things Land Rover Thumbs Up
Post #626670 Fri Sep 16 2022 9:33pm
Red Arrow
May be able to advise you
Post #626671 Fri Sep 16 2022 9:34pm
DrRob
Call Steve Norman in Shepton Mallet I would. T&S Norman. He's a guru and not too far from you * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #626781 Thu Sep 22 2022 8:43am
John1311
will do many thanks 2016 Range Rover Sport SDV6 autobiography (MY17)
Post #626857 Sun Sep 25 2022 1:31pm
Stevepd
I use exclusively T&S and Steve and George absolutely brilliant. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #626858 Sun Sep 25 2022 2:27pm
