![]() | Home > General > Sunroof drain hose L320 |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5116 ![]() ![]() ![]() |
https://drive.google.com/file/d/13XEAwZrEc...sp=sharing
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 ![]() ![]() ![]() |
Err.. Nope. I fed a wire through from the top and taped it to a new drain tube I bought. I can pull it from above the dash for about 3"then it stops and won't go any further.
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
OK there is a knack to this.
As an aside, the main cause of this is jet-washing through the side vents. The force can push the drain hose out of position, or disintegrate older hoses. Barrie.
kas982 Member Since: 03 Oct 2021 Location: west mids Posts: 53 ![]() ![]() ![]() |
so from what i understand,mine is also dislodged/rotten. only a worn gromet in the vent hole. its a rh drive car.
Most likely not missing but disintegrated and flopping down behind the vent ready to drain water in the footwell. Because there is no slack to pull through you'll most likely need to fix a new pipe. At least when it's fitted you can pull it through so you got some to play with. As I've said before, forget the grommit. It's more trouble than it's worth.
thanks, must say your idea makes sense...i better sort it before winter..lol |
I managed to repair the drain tube so the footwell is dry. Tricky but doable.
I've experienced the same problem before. The drain-holes in your sunroof may be blocked up. With nowhere to go the water sits there and eventually seeps through wherever it can. In my case the car had been sat there for a while, the water ran along the headlining and down the inside of the pillars. The inside of the sunroof cover was also soaked.
i sorted mine,it was a huge faf, but it's one of those jobs that you do it once & it becomes easy. ok, so there are a few things i'll go through that haven't been mentioned, that might help out.
Googs Member Since: 04 Oct 2022 Location: Greens Beach Tasmania Posts: 89 ![]() ![]() ![]() |
Thanks for sharing that Kas, it's a valuable bit of information ...should be in Sticky
Spitty Member Since: 28 Jun 2022 Location: Gloucester Posts: 3 ![]() ![]() ![]() |
Pulled the A pillar trim off and made the mistake of pulling the hose out from behind the fuse box. Rerouted sown the pillar and addd some extra hose. Drilled a hole out throug the floor pan and put the hose out and down below th air tank to avoid doing to the rust on the tank. |
