Home > General > Sidesteps again
Dicer
Sidesteps again
My side steps from sidesteps.co.uk arrived today and I have a question, it says in the instructions to make sure you fit the brackets as per the stickers. Unfortunately mine have no stickers so if I put a photo up could anyone that’s fitted them before identify which is which ?
Many thanks and apologies for being a tad thick.
Post #626471 Tue Sep 06 2022 6:19pm
Dicer
Don’t worry I think I’ve sussed it, in too much of a rush as usual.
Post #626472 Tue Sep 06 2022 6:33pm
karlos01
what rrs do the brackets fit please
as I'm looking for some
Post #626474 Tue Sep 06 2022 7:19pm
Dicer
2013-2022 stated on the website
Post #626475 Tue Sep 06 2022 7:45pm
Sudds
Just fitted the same steps to mine and I think they are so much better than some offerings out there as the rubber tread wraps around the edge.
Found them very easy to fit
Post #626476 Tue Sep 06 2022 7:55pm
karlos01
I'll have a look as I've got a 2006
Post #626477 Tue Sep 06 2022 8:03pm
Dicer
Hi Sudds
Did you have any problems with the rear brackets I can’t seem to get them to sit close enough to the fixing holes, I’m not sure I’ve got the v shaped bit that came with the bolt already fitted in the right spot
Post #626478 Tue Sep 06 2022 8:10pm
Sudds
The rear brackets on mine lined up ok, the 2 front holes nearest the sill required the bolts to fit through the bracket and the bolt at the back stayed in the bracket and slid into o hole in the chassis and then clamped up as i tightened the bolt, it does allow the bracket to slide to fit the front bolts.
Just need to ensure once you have fitted the step that as you adjust it up to the sill for a tight fit that the bracket slides up the back of the jacking point.
Hope this helps.
Post #626492 Wed Sep 07 2022 4:58pm
Dicer
Cheers Sudds
I’ve had another look and think I’ve found the problem, the rear off side bracket is different dimensions to the near side rear bracket
Post #626493 Wed Sep 07 2022 7:00pm
Red Arrow
I have a good set of the alloy brackets for the L494 never been fitted
Cover the carriage on them and the price of a pint you can have them Thumbs Up
Post #626497 Wed Sep 07 2022 8:05pm
Dicer
Thanks for the offer I will bear it in mind, I’ve emailed the company that supplied them hopefully they will sort me out.
Post #626500 Wed Sep 07 2022 8:38pm
Sudds
I found their customer support was really good when i had a query. Heather passed on my query to Reece and he phoned me back within 10 minutes to answer my question.
Post #626511 Thu Sep 08 2022 8:02am
Dicer
I’ve spoken to Reece and Heather this morning and they are putting a replacement in the post today, I understand things like this happen but the sign of a good company is how they sort a problem out and I must say they are excellent.
Post #626517 Thu Sep 08 2022 12:35pm
