![]() | Home > Technical > Air vent stale odour NEW pollen carbon filter fitted |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 953 ![]() ![]() ![]() |
I've noticed the same on every car I've had,,, I think it's one of those things,,, condensate will appear in the system as it moves from cold to warm. Try putting a bomb through the system,, it's helps for a while. Euro car parts were selling them for a few quid a while ago. 2010 RRS, TDV8
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1890 ![]() ![]() |
Turn on the climate control? What saving do you think you are making? 2023 P440e SE Dynamic on order -cancelled
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9068 ![]() ![]() ![]() |
Just run the climate control system. You'll save three fifths of |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 264 ![]() ![]() |
Mine is on all year round, I had endless arguments with my wife about using aircon because someone told her years ago that it used much more fuel.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5053 ![]() ![]() ![]() |
As said, that is just normal, when you turn the AC off |
I never understand people buying 2.5t SUVs and then worrying about a tiny bit of fuel usage. You want to save fuel? You're in the wrong vehicle. 2012 SDV6 - it's missing a couple of cylinders
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 ![]() ![]() |
I turned the instant consumption display on the other day out of curiosity (and because I wondered if my intermittent fault was having a permanent impact on "economy") and boy are you not wrong there.. single digits off every roundabout and junction |
