Home > Faults & Fixes > P00BD-07 MAF General failure
Abandito
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Rimini Red
Any help please… dreaded restricted performance!
Drove ~40 minutes, quick stop, restarted, accelerated and straight into restricted performance
IID shows error below
Could be be a simple clean the MAF, or replace?
Using IID is it possible to check the input values, if so, what range should it give for a good sensor?
Assume can pull up live values, but not check before, so any help would be great
RRS 2010 TDV6
TIA
Post #621269 Tue Jan 25 2022 7:41pm
Abandito
Update fixed, thought I had posted this but clearly not
Seems that taking both MAF sensors off and thoroughly cleaning with proper MAF contact cleaner has resolved this issue, though clear that one has already been changed and the other original is fairly worn.
Anyway 6m on and still running fine 😜 RRS L320 2010 facelift model 3L TDV6
Post #626359 Wed Aug 31 2022 1:21pm
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
How do the MAF sensors get dirty and/or worn. Mine are always pristine whenever I have checked them and after 11 years of owning the vehicle.
Post #626387 Sat Sep 03 2022 1:03am
Abandito
Lucky you
They measure the air flow from air filter to engine, so they will get dirty over time, especially on UK roads and occasionally off road RRS L320 2010 facelift model 3L TDV6
Post #626469 Tue Sep 06 2022 3:50pm
Meiang
I need to replace my airfilter every 6 months as it gets extremely dirty - so I dont think the English roads are any worse than those here. Downstream of the filter is always very clean i.e the filter is doing its job properly.
Post #626546 Fri Sep 09 2022 3:26pm
