![]() | Home > Technical > Recommended Engine Oil |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9135 ![]() ![]() ![]() |
https://www.advancedfactors.co.uk/service-...-198-c.asp 2012 SDV6 - it's missing a couple of cylinders
jases4x4 Member Since: 28 Dec 2014 Location: yorkshire Posts: 253 ![]() ![]() ![]() |
Think i might start doing my own servicing now with the costs over £350 from Indys for oil and a few filters! |
B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420 ![]() ![]() ![]() |
Cheers for that ![]() Is the following link the correct kit for my car https://www.advancedfactors.co.uk/kit106a-...0503-p.asp Also do you know what size socket I would need for the oil filter? Need to order one as im going to attempt to service the car myself ![]() EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED, BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR |
Thats what im planning to do, wish me luck ![]() EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED, BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR |
I dont think you can go wrong with the oil and filters, Just check diesel filter, I hd a mechanic not tighten mine up a few years ago and lost 1/4 of a tank of diesel because of this so maybe that filter needs double checking its in correct, I mean if a qualified mechanic can make the mistake then maybe its not an easy diy job. |
skid1963 Member Since: 24 Mar 2018 Location: Snodland Posts: 224 ![]() ![]() ![]() |
Very easy to crush or break the seal on the fuel filter 2015 L494 SDV6 3.0 HSE Loire Blue
Anyone know the socket size to remove the oil filter? |
https://www.fullfatrr.com/forum/topic2393.html
