![]() | Home > Maintenance & Modifications > Should I flush the transmission? |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 ![]() ![]() ![]() |
personally my self I would stick with the traditional service and drop the pan and change the filter
Well with it being 10 years old I would. When I had mine done it was the oldest car, yet the lowest mileage. Mine was flushed as preventative maintenance and I wasn’t carrying any faults, but was the blackest oil. Think there’s photos in my gallery. I suppose there is no right or wrong in which way you choose so long as it gets addressed. What are the costs you’ve been quoted?. 2006 2.7 TDV6 HSE in Cairns Blue. |
Josh95 Member Since: 08 Dec 2021 Location: Belfast Posts: 49 ![]() ![]() ![]() |
The costs are what is confusing me.
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 508 ![]() ![]() ![]() |
If you’re in the 50,000 mile range and first time, do a flush. 100,000 mile range and first time, just drop the pan. Reason being some of the buildup can be sealing things. Flush it all out and you could be in need of changing a bunch of seals.
I agree with NoExpert. If I was in your shoes I’d be flushing. If so in 50/60k’s worth and your still planning to keep the car then flush it. The mobile guy, is that in the province or is he coming across from the mainland?. 2006 2.7 TDV6 HSE in Cairns Blue. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4526 ![]() ![]() ![]() |
Gearbox issues are caused by dirty oil
The car is at 110,000 miles. Haven’t had it for a year yet but plan on keeping it. He’s in the province about 50 miles away. |
Abandito Member Since: 13 Feb 2017 Location: Preston Posts: 24 ![]() ![]() ![]() |
12m ago had a flush by Bodsy, at around 174k miles, found oil was black and deposits, so needed a change
Sudds Member Since: 02 Mar 2015 Location: North Yorkshire Posts: 36 ![]() ![]() |
I've had a couple of gearboxes flushed and never had any issues. Both boxes were noticeably smoother on shifting and on both occasions i was surprised at how discoloured the oil was. Well worth having it done. |
Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 225 ![]() ![]() ![]() |
Had mine done when I got it 3 years ago on the advice of my indi, smooth as silk since having it done it had done around 80,000 miles at the time. |
