![]() | Home > Technical > Couple of Minor Issues RRS 55 plate. |
Yes, the RRS is a whole other animal from the RR.
Brian Considine Member Since: 26 Mar 2022 Location: SE UK Posts: 93 ![]() ![]() |
Thanks, looks like I may need to find a good Indy in my area (East Kent) to switch off the cornering lights.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5094 ![]() ![]() ![]() |
So the cornering lights only come in while Corning or on all the time ? Just take the bulbs out.
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 316 ![]() ![]() ![]() |
The cornering lights never worked on mine so I’ve installed Led bulbs and rewired as DRL’s. Steve
skid1963 Member Since: 24 Mar 2018 Location: Snodland Posts: 219 ![]() ![]() ![]() |
Try Ansells Service Centre in Lydd Used them a few times, Jason and Dan are ex JLR so they know what they're doing and reasonable for price too 2015 L494 SDV6 3.0 HSE Loire Blue 2006 L320 4.2 Supercharged - Gone 2009 BMW X5 M-Sport - Gone 2007 L320 2.7TDV6 SE Buckingham Blue - Gone 2011 Jaguar XFS 3.0V6 Diesel - Gone 2009 (59) L320 Facelift 3.0TDV6 HSE White Wrap - Gone 2008 BMW X5 M-Sport - Gone 2005 Audi A6 3.2V6 Quattro S-Line - Gone |
Cornering lights should come on with turn signals or while driving under a certain speed coupled with the steering wheel turned a certain amount. I believe driver side comes on later in steering wheel turn than passenger side. I like mine, but I tend to drive through small villages and on country roads where lighting can be few and far between. There have been a few instances where my car lights are the only lights visible in any direction as far as I can see. It’s almost a light show with the adaptive headlights, cornering lights and auto high beams doing their thing.
Double checked the cornering lights & they only seem to work at low speeds so I can live with that. Thanks for the link - looks like a couple of relays & a little time to fit. |
Thanks, pity they are so far from a station (if I have to leave the car). |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 ![]() ![]() ![]() |
cornering lights on my 2006 plate sport comes on when I do less than 20-30mph
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 305 ![]() |
For the seat issue there switch panel is just screwed onto the plastic seat valance , there's 2 pins at the top that pop out then its 4/5 torx screws holding the seat button controller and its just connected with a long connector - just double check no wires are loose on it - you can buy the seat button controllers quite cheap from ebay also. |
Thanks - I'll have a look. |
