| RRSPORT.CO.UK | ||
|  | Home > Technical > RRS MY 2007 TDV8 - noise from leaking exhaust manifold |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | A quick look online suggests that a genuine exhaust manifold for the TDV8 is over £1000 just for the part. With other bits and pieces (there's always other bits and pieces required) plus labour to lift the body and do the actual work, I can see why the price is getting so high these days. 2012 SDV6 - it's missing a couple of cylinders
|  Thu Jul 21 2022 1:05pm |
| RangeGer Member Since: 21 Jul 2022 Location: Düsseldorf Posts: 4      | while not wanting a NEW exhaust manifold it will reduce the price just to fix the manifold by 90%
|  Thu Jul 21 2022 1:33pm |
| aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447    | Is the problem that the manifold is cracked, or that the head-side mounting face is warped (common on TD5s)?
|  Thu Jul 21 2022 3:59pm |
| RangeGer Member Since: 21 Jul 2022 Location: Düsseldorf Posts: 4      | Thanx a lot
|  Thu Jul 21 2022 8:53pm |
| aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447    | If you can get it off, then, you just need a local machine shop.. granted, at least over here, those are becoming a little rare! The only ones I can find on Google near you seem to be large industrial shops, and you really want a smaller place that will do one-off jobs - or a guy with a Bridgeport/Thiel/Deckel in his garage  | ||
|  Fri Jul 22 2022 8:19am |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | Every one we've had with snapped studs, we've had the manifolds skimmed
|  Fri Jul 22 2022 8:48am |
| Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 278    | Many, many, years ago as an apprentice in a machine shop I used to do the same with cast iron cylinder heads, the trick is to clamp the item on the mill while retaining the 'warp' so once unclamped, the freshly machined surface remains flat.
|  Fri Jul 22 2022 10:11am |
 Exactly what I think. Had it done that way two years ago now the other side causes trouble. This was the manifold after taking it off from the engine. You see the broken bolt as well. I paid 1.000 EUR for the complete repair. That workshop has a new owner now and he asks 3.000,- for the same job now. Wondering how much they usually charge in the UK to fix it, without installing a new manifold.     | ||
|  Sat Jul 23 2022 10:43am |
| Posting Rules
