![]() | Home > Technical > Hdc fault. No quick fix |
| Mickmac Member Since: 15 Jun 2018 Location: Amble Posts: 16
I had the same symptoms,turned out to be a wheel bearing ,worth a check |
| Toonraider Member Since: 15 May 2022 Location: Newcastle upon Tyne Posts: 117
Forgot to mention, new wheel bearings both fronts and all new discs and pads. |
I can replicate this with ease. Strangely.
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
Does the suspension drop to the stops?
Yeah, white lines above and below each wheel and red boxes across the axles. |
| karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309
Almost certain mine shows the same. Will put a pic later if I can work it lol |
Here's mine before it falters. |
Ha, knew I'd cock it up
have you got anyone near you who with a diagnostic and see what fault cods you come up with? |
Seeing someone on Sunday but with an icarsoft system. |
that should help you out with a fault code
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145
Try pressing the dsc button before you set off
| All times are GMT |
