![]() | Home > General (L494) > New Owner :) - Couple of quick ones - Electrical based |
Coedlan Member Since: 30 Sep 2016 Location: N. Wales Posts: 71 ![]() ![]() |
Oil question is simple, though baffling as to why LR designed such a daft system
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 311 ![]() |
Ah I tried the oil indicator at the dealers but had only been running for 5 mins and I tried when I got back but car had been running for a good 4 hours after driving - just see the bonnet trick will check that out tommorrow. |
Going to try the bonnet trick this morning to get the oil level.
jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1916 ![]() ![]() |
You will not need the bonnet trick, if the car has not been started.
Still struggling with the oil level indicator |
There are/were several stages of Meridian, you may have the basic? 2026 P460e Autobiography on order
Ah :/ that’s maybe why I can’t see a surround sound option, but have the 3 other sound options but obviously can’t select them :/ - not sure if it’s an amp issue or electrical issue as the sub is non existent when I turn the level to max. |
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 ![]() ![]() ![]() |
There was an advisory to dealers on the oil level indicator. Mine was fixed under the original warranty before the 3 years was up. Oil flows up the wiring in the sump basically stopping the signal from getting to the computer. Its an expensive item to get fixed. Basically it is a stupidly designed system to replace a dipstick!
Thanks Barry - looks like it will be the sensor - so I’m covered under my extended warranty so will get that sorted.
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 595 ![]() ![]() |
Approx 1 litre from min to max and is 125ml per section on the indicator
Did you try the oil level check with the engine warm, level ground etc? I guess you did but still not available?
Ah cool thanks for the replies guys - I'll prob leave it for now until its booked in then.
Yeh tried all the usual tricks to get it to show including the bonnet open and pressing cancel twice etc |
Interesting thought, though if the sensor is goosed then an obd wouldn’t get the data either? I did wonder if a length of bicycle brake wire or similar could be fed down the oil extraction pipe to “dip” the oil level. Haven’t (yet) tried it, but the bends in the pipe look tight so may not be possible? 2016 L494 HSE |
