![]() | Home > Maintenance & Modifications > L494 rear diff failure |
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 481 ![]() ![]() ![]() |
Sorry put this on wrong thread |
Did you top it up with oil.? If I was you I’d top it up,it goes in the plug where it was leaking,as you top it up,as soon as it starts to run out that means it full.put bung back in give it a really good clean & run it for a few weeks & check it again. Andy.
So this is where you fill the diff with diff oil then?? |
I’m trying to work out from the pic wether that bung is the bottom one or the one half way up,,you fill it with the one half way up. Andy.
It’s definitely the bottom one. It’s the only one I can get to without lifting the car |
Would this only leak when the engine is warm or all the time? |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1204 ![]() ![]() ![]() |
that is definitely the drain plug, the only thing you can do is to tighten it now until you can it to a workshop/change the oil yourself.
