Home > Technical > DPF ISSUE |
skid1963 Member Since: 24 Mar 2018 Location: Snodland Posts: 188 |
Link to a post on here about this but not sure it answers your question....sorry
Mon Jun 20 2022 11:21pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
Are you sure it doesn't have a DPF fitted? Some 2008 TDV6 could have them fitted. You'd need to physically check to see if there's one there. Or perhaps it's had one removed and a bodge done to fool the ECU and the bodge has now failed causing the error.
Tue Jun 21 2022 9:44am |
Sween23 Member Since: 11 Jan 2022 Location: Lancashire Posts: 10 |
thanks for the reply
Tue Jun 21 2022 11:28am |
Ah, a proper bodge job then. That's a real . 2012 SDV6 - it's missing a couple of cylinders
Tue Jun 21 2022 5:19pm |
I did an ecu flash with the IId tool and it seems to have solved the problem 👍 |
Wed Jun 22 2022 12:26pm |
Good news. 2012 SDV6 - it's missing a couple of cylinders
Wed Jun 22 2022 3:40pm |
