![]() | Home > General (L494) > Rear diff oil leak |
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 479 ![]() ![]() ![]() |
Don’t know why photo is upside down. Can’t turn it round |
jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1901 ![]() ![]() |
Because you were holding the iPhone upside down! |
It’s the right way up on the iPad where I sent it from |
Of course it is, the non standard orientation info stored in the photo by Apple will be understood by any Apple device.
Skyline Member Since: 01 Jun 2022 Location: Hertfordshire Posts: 97 ![]() ![]() |
Had this on mine - is a known issue and was covered by LR aftermarker warranty. Hope you get it sorted. P MY23, 3.0 P440e PHEV AB, Carparthian Grey, Deep Garnett interior MY16, 3.0D HSE Dynamic, Barola Black, TV, Rear Entertainment, Opening Pan Roof, Meridian |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9086 ![]() ![]() ![]() |
In your gallery, select the image and then immediately below the image is a button to "crop and rotate". 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1199 ![]() ![]() ![]() |
it's the infamous rear diff pinion seal leak - there is a recall for that fix, it should have been done under LR warranty.
So I had a look under car today and found what could be the cause of the leak. It looks like some sort of nipple with a square hole in it. It looks like it can be removed or tightened up and no doubt will have a seal of some sort. What do you guys think?
I have wiped the moisture away so on some photos looks dry ish |
Nick900 Member Since: 11 Mar 2022 Location: Kent Posts: 87 ![]() ![]() |
It is the drain plug. Changed my diff oil last week. To resolve just buy a new one. You will need to slacken the fill plug first do this before you do anything else in case you can't remove it. Otherwise messing with the drain plug you loose oil undoing then cannot refill. Takes about 0.8l.
I’ve had a sheet of cardboard under the car now for 1 day with not a drop of fluid on it. When I take the car out over the weekend I’ll keep the sheet under it to see if it leaks when engine is warm. |
Check how tight it is, should be 30NM |
So I’ve pulled the car out of the garage and raised it up on the air suspension to get a better look. I know it’s not a good idea to get under the car in case it comes down by itself but I was very quick…..So the leak looks to me like it’s coming from the shaft that goes in then I assume the fuel is tracking down to lowest pint that is the drain plug. Photos attached. I’m getting worried now. I’m hoping this is covered with my WD warranty. I’m going to contact JAS tomorrow to see if it’s something that would be covered by a warranty.
