![]() | Home > Faults & Fixes > Multiply misfires random |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 352 ![]() ![]() ![]() |
The random nature of the misfires
More investigation and playing with the ID tool my egr is reading -100% looks like it's jammed open but shows no codes.
Unless some one can tell me different.....I am unable to find an egr on this engine |
After a brain storm im going to replace the sc snout bearings as there fecked I'm thinking there causing the knock sensors to misread the vibration from the faulty bearing as cylinders misfire........Will check again after sorting the sc snout. |
Mccolganm4 Member Since: 14 May 2021 Location: Dundee Posts: 68 ![]() ![]() ![]() |
I'm following this. I have a very similar thing going on with misfires and my supercharger is rumbling a bit too. I think mine is just the coupler but if your bearing/coupler fix works I'll send you my charger to rebuild👍 |
Haha iv had the full repair kit sat here almost since I got the car I think it was the 1st thing I bought for it but the vac leak and other minor issues needed sorting 1st |
Am still waiting todo this as iv been very busy with work and sadly had x3 deaths in the family to deal with iv got some time off comming up so will pull the supercharger off strip it down and rebuild it.
Just to close this 1 iv had the bearings and coupler replaced in the sc snout today and can report no more random misfires
