![]() | Home > Maintenance & Modifications > Aux coolant pump |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 355 ![]() ![]() ![]() |
Found it
Well the fuse it good so just need someone to confirm the pump should run constantly as I would expect it to |
Mccolganm4 Member Since: 14 May 2021 Location: Dundee Posts: 68 ![]() ![]() ![]() |
Yeah it should. I had a similar problem last summer. I replaced the pump and checked the wiring. It hadn't been changed so the pump had been running backwards since 2006. Was easy enough job. There is a TSB about the wiring but I can't remember the number sorry. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5151 ![]() ![]() ![]() |
Google LTB00041 plenty of info. will come up.
Thanks guys, got all that. The wiring was back to front iv rewired the plug connected it back up and nothing soooooo hit the pump with the end of a screw driver and it fired up.
Decided to swop out my failing supercharged aux cooling pump it was wired back to front from factory but dispite my rewiring it correctly and the pump running after a whack with the end of a screw driver it just didn't recover.
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
Good to know thanks. And well done for sorting it! |
Well that new ebay aux pump has failed all ready will be fixing the old pump iv stripped it down the brushes are worn out no surprise there. Will take a few photos and post back just gotta find those spare motor brushes I keep safe just incase I ever need them. |
Genuine bosch pump arrived today, 15 mins start to finish. Replaced the bonnet sensor to as the alarm was random going off. Don't waste your time on the cheap ebay pumps.
