![]() | Home > General > SVR Towbar question |
| Jjvd21 Member Since: 20 Dec 2011 Location: Chicago Posts: 262
That is an absurd price, if you are able to install it yourself you will save half. The towbar piece itself is roughly $1,400 new. The rear diffuser piece is about $250. You will then need to have the dealer enable tow electronics. 2020 SVR / R.I.P. 2019 SVR / 2016 D4 Landmark / 2005 D3 HSE |
| Darbs Member Since: 03 Dec 2015 Location: Cheshire Posts: 96
Hi, I’ve had a aftermarket tow bar fitted to my 2021 SVR. All you have to do is remove the rear diffuser when your using it, I use a 20 pence piece to do it. It was fitteded at North West Towbar in Stockport, cost £550. The only thing you don’t get is the reverse sensor delete when reversing, which I can live with for how much towing I do. Great for a bike rack also !!!
Just noticed your in Cornwall 😬 |
| Cyberstaff Member Since: 13 Jun 2022 Location: Cornwall Posts: 5
Thanks, is it a removable one? Sounds perfect i'm not keen on loosing the rear diffuser. Do you have any links or photos? |
Hi, yes it’s a detachable one.it’s made by Westfalia. |
Thanks for this. i took my diffuser off tonight to see and its pretty easy so hopefully i can sort something. |
Any other details you can share? 2020 SVR / R.I.P. 2019 SVR / 2016 D4 Landmark / 2005 D3 HSE |
So i have done a bit of research online as well as looking at my car.
| Cred Member Since: 10 Jul 2024 Location: North East Posts: 1
Hello,
| All times are GMT |
