Home > Maintenance & Modifications > Underbody surface rust.... looking for recommendations |
Iomegas Member Since: 16 Nov 2020 Location: Newcastle Upon Tyne Posts: 206 |
Hi can’t recommend Lanoguard enough excellent quality ,easy to use spreads well and you can get a pack that contains a tub of there fantastic grease to use also on exposed bolts for extra protection.Great product I fine much better than Waxoyl that I previously used. https://www.lanoguard.co.uk |
Fri Jun 03 2022 12:06pm |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 |
I second Lanoguard. Easy to apply yourself. Can do the whole underside in an hour or less. I had Dinitrol applied to my last Sport but found it horrible to work on underneath once it was applied, it’s like a tar. Lanoguard is lighter, can be done at home, contains all natural ingredients (no petroleum based chemicals) and is a UK family owned business with excellent support. For £70 you can do the whole underneath and have plenty left over. 2016 RRS SVR Estoril Blue
Fri Jun 03 2022 12:22pm |
RRT Member Since: 26 Mar 2018 Location: South Coast Posts: 237 |
How long does Lanoguard last in real world use? MY17 RRS 4.4d V8 Autobiography - Aintree Green (also referred to on Topix as British Racing Green) |
Fri Jun 03 2022 2:36pm |
Hi I have had it nearly 15 months and went under and checked last week I only had a minimal touch up to do ,I think Lanoguard recommendation is to check yearly . |
Fri Jun 03 2022 3:43pm |
Kensta Member Since: 17 Feb 2011 Location: North east Posts: 697 |
Cheers everyone ,lanoguard sounds good , what preparations did yous make to your vehicles before applying it , did you wire brush and did you have to use some kind of rust killer too before the lanoguard ? Java black 2006 |
Sun Jun 05 2022 1:00pm |
HI yea did a bit prep with. wire brush Lanoguard can be sprayed onto surface rust with no issues and doesn't require a highly prepped and keyed up surface. The lanolin will be attracted to the metal underneath and slowly push off any existing rust. |
Sun Jun 05 2022 2:07pm |
That’s great Thankyou , think il give it a go this weekend , I’ve got a set of Ramps il drive it up onto and slide under Java black 2006 |
Mon Jun 06 2022 9:11pm |
Enjoy one thing I would make sure is you have some eye protection on if I was you if your outside it can carry easily . |
Tue Jun 07 2022 7:10pm |
Cheers yeah I did think it will be a messy job Java black 2006 |
Tue Jun 07 2022 10:43pm |
It’s worth getting the Lanoguard pack with the grease included also you may even get good weather to do it lol like you I’m in North East also so weather can be a bit unpredictable |
Wed Jun 08 2022 6:15pm |
