Home > Technical > L320 accelerometer wiring colours
joboco
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Lux Java Black
Does anyone know the colours of the wires that go to the accelerometer that sits beside the Dynamic Response valve block. I have just finished fitting new front ACE pipes and am now getting the following code (C1A97-62 (AF) Lateral accelerometer circuit - Algorithm based failure - signal compare failure) There are 2 wiring harnesses in that area, one to the valve block above the front ACE pipe coupling and one that goes to the accelerometer. The thing is both connecters will fit both sockets (if that makes sense). I think I might have put them on the wrong way round.
I would be very grateful for any help you can give.
Post #624408 Sat May 21 2022 4:16pm
accelerometer wires seam to be
yellow black 5v
yellow pink ground
orange grey
Post #624412 Sat May 21 2022 5:27pm
joboco
Cheers for that. I think mine must be the wrong way round.
Post #624436 Sun May 22 2022 3:43pm
If one of the the plugs is Grey that is the accelerometer one, according to the electrical reference library the ones on the Dynamic Valve block solenoids are Black.
Post #624444 Mon May 23 2022 12:04am
joboco
Cheers Col, that is just what I have been trying to find.
The vehicle is now working as it should. That's a big saving on labour.
Post #624448 Mon May 23 2022 7:10am
joboco
yellow black 5v
yellow pink ground
orange grey
Thanks Andy, yes you are correct about the colours as I've recently discovered.
Thank you for the help, all is now working as it should.
Post #624454 Mon May 23 2022 11:24am
