Home > Technical > RRS L320 black outside door trim
OB42UK
United Kingdom 2013 Range Rover Sport SDV6 SE Baltic Blue
Hi guys, does anyone in here knows if and how to remove the outside black door trims that stays in between the front and back windows it has a torx stew from the inside the door but I don’t know if that is for the trim.
Thanks to all
Post #624317 Tue May 17 2022 5:52pm
If I remember correctly the front door has two of the small torx screws one each end and the rear door just the one, remove the screws and just lever/pull the trim upwards to remove it, if you don't want to reuse the trim just give it a good pull, if you do want to reuse them lever off very carefully as they do bend very easily.
Post #624321 Tue May 17 2022 9:33pm
OB42UK
Hi Col,
Thank you so much for your reply, I will do as you sugested as I will be re-use the trim as I only want to give it a good paint as they fade together with the front and back ones.
Regards
Orlando
Post #624327 Wed May 18 2022 7:31am
