Home > Maintenance & Modifications > Gearbox update
Jimes256
United Kingdom 2007 Range Rover Sport TDV6 HSE Bali Blue
Gearbox update
Hi all. 2007 tdv8 here. Was wondering if a software update might help with clunk between 1st and 2nd occasionally? Is there anyone near Bath that can update? Thanks
Post #624220 Thu May 12 2022 9:32am
Bertbuckie
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Bonatti Grey
Im not an expert, but I would imagine you would be better giving it a mega flush.
There are software updates available via IID tool. I did my BCM the other day but its £25 an update and some are UBS dealer only so youd have to ask them. Also, youd need the IID tool.
Post #624221 Thu May 12 2022 9:38am
Jimes256
It’s had a flush and the metal sump conversion
Post #624222 Thu May 12 2022 9:49am
Bertbuckie
How many miles out of curiosity? I had an auto Volvo do this and it was a build up of hot oil scum on the solenoid valves. Was an absolute pig of a job to change them out.
Post #624223 Thu May 12 2022 9:51am
How many miles has the gearbox done? It might just be a simple case of wear and a software update won't cure that, sadly. 2012 SDV6 - it's missing a couple of cylinders
Post #624224 Thu May 12 2022 9:52am
Jimes256
125k. Solenoids all clean. Just read lots about update helping with this
Post #624225 Thu May 12 2022 9:56am
Bertbuckie
You can try it, but I have my doubts. How can you tell they are clean? Have you had the vavle body out etc?
I really recommend the iid tool but it isnt cheap - GAP's customer support is second to none so ask first as it may only be dealer updatable.
Post #624226 Thu May 12 2022 10:00am
Jimes256
Yes had the mechatronic out and checked solenoids. I know it’s not specific but I have a snap on solus and not sure if sport will be long term so reluctant to buy another reader. Was hoping someone would be close by who could try an update 🙏
Post #624230 Thu May 12 2022 11:58am
Bertbuckie
Try land rover or indy garages. The issue with iid is it binds to one VIN unless its a garage tool ( and costs a lot ) would be my advice, but I fear your not going to get what your looking for. When it was flushed was a calibration done etc?
Post #624231 Thu May 12 2022 12:01pm
Stevepd
I’m sure T&S Norman do flushes, not to far away. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #624239 Thu May 12 2022 4:58pm
Jimes256
It’s been flushed
Post #624240 Thu May 12 2022 7:40pm
Jimes256
I thought there would be someone on here that provides software updates
Post #624241 Thu May 12 2022 7:41pm
