![]() | Home > Maintenance & Modifications > Rear Active Anti Roll Bar |
Lynchy Member Since: 24 Oct 2021 Location: Newcastle Posts: 80 ![]() ![]() ![]() |
Do i just need the LR024073 part? Ive found one at a garage that has come off a 3.0. Is this just a straight swap? |
If this completely drains of fluid, what is the risk? Reason i ask is its leaking now, but i need to drive it to to pick up the part and then drive it to a garage. Is it safe? |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9099 ![]() ![]() ![]() |
I'd fit a new OEM bar. £600 plus fitting. At least then you know you're starting with a good item rather than an unknown second hand one.
Thanks mate. Understand the pump will run dry, but is it still safe to drive? |
It'll be rolling around in the corners but if you go gently you should be ok I'd have thought. If the car figures it's unsafe, it'll throw up a red warning light.
That was going to be my next question. Where is the tank, and i will keep it topped up for now. |
It's on the left hand side of the engine bay, near the front, and it's got a yellow cap on it. The other yellow cap - over by the coolant header tank - is the power steering reservoir. 2012 SDV6 - it's missing a couple of cylinders
Just checked there, and its well below the min level (about 1cm). Can you get any ACE fluid?
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4513 ![]() ![]() ![]() |
We always replace the pipes when doing a rear bar. We're about £900 less than your quote though. Maybe ask for an itemised estimate ![]() |
I'm hearing good things about Lucas Stop Leak Fluid also. Have you heard anything on that as a quick fix? |
He said he can do the change for £600 if i supply the Bar. Second hand Bar is around the £200 mark. So looking at £800 now. |
