![]() | Home > General > Side Step Trim Falling Off :( |
Xstyle Member Since: 14 Jul 2014 Location: Berkshire Posts: 46 ![]() ![]() ![]() |
Thank you! I presume OK for the 2010 L320 model too, as listed from 2013+?
Just use Stainless Steel pop rivets won't corrode again, all side steps on the RRS1 are the same although the kit part number changed when they changed the plastic trims included in the kit from pre-cut ones to uncut ones to save a few pence.
Do you HAVE to take off the side step first?
... and will this do the trick?
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 ![]() ![]() ![]() |
you can do it underneath with the clamps
I used 4.8mm head stainless steel rivets.
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 273 ![]() ![]() |
An old trick when using pop rivets is to put a washer on the other side to the rivet head so the expansion of the rivet grips the washer, not the base metal. This enlarges the clamping area, particularly useful if the original hole is in poor condition due to corrosion. Use a washer sized as close to the rivet as possible and of course make sure the rivet is long enough to clamp all 3 parts. RRS HSE Dynamic SDV6 2014
Yeah, it fell off. Didn't go through at all.
Extra long length rivet heads, up to 20mm.
Shall I buy the 20mm head length?
