Home > Technical > Intermittent EAS Fault |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8849 |
The issue where it doesn't lower and instead extends is often caused by the EAS exhaust valve not working properly. The system says "hey, lower" and when it doesn't see the ride height lowering it assumes a grounding issue so raises to allow you to clear the obstacle. It doesn't know about the valve sticking. The exhaust valve is usually considered a non-serviceable part inside the compressor but there was a post on here where someone did repair it.
Wed May 04 2022 2:03pm |
Kitchenfitter Member Since: 20 Feb 2021 Location: CV61AH Posts: 349 |
I have similar issue but being sorted next week. Apparently the filters can be changed but will know more next week RRS HSE DYNAMIC 2015 ODESSEY RED |
Wed May 04 2022 4:48pm |
Josh95 Member Since: 08 Dec 2021 Location: Belfast Posts: 49 |
How did you get on? |
Fri May 20 2022 11:09pm |
Still waiting as i am having timing belt done to. But the belt is on back order so car is at the garage with no timing belt, should be in stock 30th so should lnow more then 🤔 RRS HSE DYNAMIC 2015 ODESSEY RED |
Sat May 21 2022 4:28am |
