Home > Maintenance & Modifications > 2.7 2005 ns head removal.
looneyfitter
2005 Range Rover Sport TDV6 HSE Alaska White
Evening. So unfortunatly the cam chain snapped. Replaced hoping may be ok. Started ok but runs lumpy. Pulled injectors to do compression test, front and middle 12bar but rear 0 so im assuming valves bent. Cam and followers look ok.
So ive removed all belts, rocker cover, cams. Whats next to pull the head off? No idea how to get to the exhaust.
Ive got a 2 post lift so hoping makes it simplier.
Cheers.
Post #623948 Fri Apr 29 2022 7:49pm
kas982
United Kingdom 2005 Range Rover Sport Supercharged Bonatti Grey
if you have a lift, its easier to lift the bod away fronm the chassis, remove the air con gas, if you dont have a machine get a mobile guy out.
Post #623981 Sun May 01 2022 3:44pm
looneyfitter
Is there a how to on how to lift it mate?
Post #623986 Sun May 01 2022 5:58pm
Couple over here and video on YouTube by pistonsbroke
https://www.disco3.co.uk/forum/body-removal-76002.html
Otherwise you would unbolt the exhaust manifold thru the wheel arch. (Remove and mark heatsheilds)
The rear belt and cover is a Real pain with body on
Post #623991 Sun May 01 2022 7:30pm
looneyfitter
How long would you say it takes to remove the body mate? If its not that long, then may be worth it as I would strip the OS head too and replace the chain and valve seals.
Might be a better way?
Post #623992 Sun May 01 2022 8:30pm
Dunno
By removing the body you get distracted with all the other body off jobs.
Rear brake lines , rust proof chassis
The OS head cam be done body on
Post #624000 Mon May 02 2022 10:00am
looneyfitter
Your not wrong there. Im already thinking of whipping the os head off, doing the gasket, all seals etc. Injectors, stems.
Whats best to use on the chassis? Will also do rear lines.
Post #624005 Mon May 02 2022 11:55am
Have a look over on disco3 for inspiration
Post #624012 Mon May 02 2022 5:31pm
looneyfitter
Busy day today. Managed to lift the body and pull both the heads off. Pots and pistons look spot on, still see the honing marks.
The valves also look fine so not sure why had no compession at all.
Post #624036 Wed May 04 2022 10:05pm
looneyfitter
Few pics
Post #624037 Wed May 04 2022 10:06pm
well if you remove the cam, turn the head upside down.
and pour petrol over the valves, wait 15 mins, that will tell you if the valves leak.
If the petrol remains, the valves have a good seal.
Post #624039 Thu May 05 2022 12:06pm
