![]() | Home > General (L494) > P400e - engine footwell rattle |
slingshot Member Since: 28 Feb 2022 Location: Birmingham Posts: 20 ![]() ![]() |
mine have little rattle when the car engine is running and idel station |
HaggisMan Member Since: 24 Apr 2018 Location: Glasgow Posts: 139 ![]() ![]() |
Anyone got any more thoughts on this? The dealer had a look last week and noticed the rear of the underneath skid plate has been damaged somehow - goodness knows how as it’s never been off-road - and thinks that it may be caused by that somehow. They wanted nearly £200 to take off the skid plate to see if that’s it, and quoted over £700 if it needs replaced, so I’ve not done anything yet as I don’t often hear it and I’m not convinced that’s the cause.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9153 ![]() ![]() ![]() |
If the dealer is claiming that there's damage from off-roading and you know it's never been off road, ask them to show you on the car exactly where the damage is. Sounds like the usual main dealer fob-off. They'll charge you to "investigate" it, do nothing and leave you with the rattle and a hole in your wallet.
I decided to call out LR Assistance to take a look in case there was anything serious. Within about 10mins the guy found two plastic pipes/tubes which he thought were likely something to do with air con which were vibrating and touching together behind the front footwell when the engine was at idle. One cable tie later and the problem is solved. Brilliant job from LR Assistance! |
