![]() | Home > General (L494) > Battery life |
LesW Member Since: 30 Oct 2021 Location: Pays de la Loire Posts: 95 ![]() ![]() |
5 or 6 years is about normal before they start to fail, so, if you are still on the original I would recommend changing it.
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 482 ![]() ![]() ![]() |
I have a 2015 RRS too and it’s on its original battery. Used as a 2nd car so sometimes doesn’t get used for 2 or 3 weeks. I always put it on a CTEC charger when I know I’m not using t more often. I’m under the impression that the CTEC charger can also recondition the battery so if it’s on it’s way out it could possibly fix it. I know that if I use the car for a few days then put it on charge it takes almost of full day for the CTEC charging lights to be all fully lit so I assume the car has a lot going on behind the scenes that uses a lot of battery power. |
Also don’t forget about the stop/start battery,,I had same problem with one of my L494’s saying low battery,it wasn’t the main battery that was the problem it was the stop/start battery. Andy.
Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 225 ![]() ![]() ![]() |
Changed my battery in March 2021, the previous one had lasted exactly 7 years . |
Kevin-t Member Since: 10 Sep 2019 Location: Sheffield Posts: 124 ![]() ![]() |
Boxer's wrote.
3hcp Member Since: 04 Nov 2021 Location: Devon Posts: 81 ![]() ![]() |
Thanks for the info, I’ve already done a reconditioning with the Ctek so it’s probably the battery or stop start one .
. Hi Kevin, I purchased a Yuasa from Halfords to replace the one that had died which was labelled Land Rover who would have manufactured that I don't know, have had no problems since fitting the new one which has a 5 year guarantee, I took great care fitting the it after finding instructions how to do it on this forum. |
