Home > Technical > Lower Suspension Arms - Which ones to get?????
Cymru001
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Stornoway Grey
Hi everyone,
Whilst getting the car services last week, the garage identified the dreaded knocking as being from the lower suspension arms. They quoted me £498 per side to repair. When I picked myself up off the floor, I asked why is it so expensive given my car is now 10 years old, they said they only fit genuine LR parts. They said they have had issues with fitting after market arms only to have the car come come back with the same fault quite soon after.
My question to you knowledgeable lot is, are there any good quality after market lower suspension arms available or do I need to put my big boy pants on, suck it up and pay the money?
I am located in Newport, South Wales and so if any of you know of a garage which can also do the work, I would be glad to find out.
Thanks eveyone
Post #623487 Sun Apr 10 2022 10:49am
Meyle HD kit from Advanced Factors 4 year warranty, good quality and perfect fit.
Post #623488 Sun Apr 10 2022 11:17am
PC76
What Col said.
I changed mine out for the meyle not long after purchasing my L320 and they lasted until I part ex it last year after 100K and some fairly decent off roading.
Wouldn’t hesite fitting them to my new one when the time comes. 2015 4.4 Autobiography
2010 3.0 HSE 162K - Gone
Post #623489 Sun Apr 10 2022 12:23pm
Disco_Mikey
All we have ever fitted is Meyle HD, and we've never had an issue in nearly 7 years of fitting
Not the cheapest of arms available, but certainly the best option Thumbs Up
Post #623492 Sun Apr 10 2022 1:43pm
Crraigymmmmm
United Kingdom 2012 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
Why dont people re use the original arms but replace the bushes and ball joint?
I assume its because paying garage labour it isn't as cost effective but I managed to fit LR ball joints, poly bushes and new LR bolts for under £120 for both sides. Obv wheel alignments after but all in less than £200, surely this is only 3-4 hours work for a garage.
Post #623515 Mon Apr 11 2022 8:31am
Quite often, it seems, the bolts seize and the arm is cut off which obviously prevents reuse. 2012 SDV6 - it's missing a couple of cylinders
Post #623519 Mon Apr 11 2022 9:01am
Crraigymmmmm
I had two seized bolts and cut the bolts and bush with a recip saw without affecting the arm. all on my drive in half a day for both sides.
It sounds like garages can get lazy and just cut the whole thing off and get the customer to pay for the hassle.
Post #623520 Mon Apr 11 2022 9:41am
Disco_Mikey
4 hours labour @ £60 p/h
£240 (+ VAT)
£120 in parts (sounds cheap)
Little over £400
Complete new arms are £100 less...
Post #623521 Mon Apr 11 2022 10:04am
Crraigymmmmm
Guess it makes sense for the DIY mechanic then but not so if paying Labour, fair enough.
Post #623525 Mon Apr 11 2022 11:11am
Add in the 4 year warranty that the Meyle parts come with. If your local mechanic fits the bushes in your existing arms, is he going to give that sort of back up? Possibly not. 2012 SDV6 - it's missing a couple of cylinders
Post #623529 Mon Apr 11 2022 4:25pm
Crraigymmmmm
Why would you need it on poly bushes. They will out last my car and for the gen LR ball joint parts they lasted 10 years so can't see them being an issue. My point is that the jobs a half day job diy so I have no idea why some places charge so much. If your not up to the job then only use an indi with good parts though. Something rewarding in that I have gen lr arms and ball joints with nuke proof bushes and saved a fortune.
Post #623531 Mon Apr 11 2022 6:20pm
Disco_Mikey
Polybushes are a bit hit and miss. Some cars, thru are very harsh. Other cars, you do get away with
With the HD arms, they are still rubber, and as such, still have their compliancy and nowhere near as firm on the road Thumbs Up
Post #623534 Mon Apr 11 2022 8:07pm
Buckster
More than happy with my Superpro poly bushes in original arms Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #623535 Mon Apr 11 2022 9:18pm
Disco_Mikey
Superpro aren't just any old poly bush though Wink
We done a family members D3 with full set of Superpro bushes nearly 5 years ago. I had it for a few days not long after, and actually forgot we had redone it all, it drove that well
And its not had a single suspension bush replaced since Thumbs Up
Post #623536 Mon Apr 11 2022 9:43pm
I fitted a pair of new lower arm that already had poly bushes fitted, put up with them for about two weeks, found them just to harsh so binned them and fitted the Meyle one's instead and they have been fine ever since, personally couldn't be bothered pratting about just changing bushes to save a few quid. Will say I don't know what make the poly bushes were though only that they were a black material.
Post #623540 Mon Apr 11 2022 10:31pm
