![]() | Home > General (L494) > L494, Main battery Replacement instructions |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1200 ![]() ![]() ![]() |
Hi chaps,
pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 413 ![]() ![]() |
the varta one is the closest and known brand, not sure on the others but also the price is reflective im guessing, Id always go known brand with a battery, until some of the other are tired and tested, too many copies about that are never to be found again should you need to claim on the 5yrs warranty. If a jobs worth doing, get a someone who knows what they are doing to do it!
Yeah, thinking the Varta or the Exide are the ones to go for.
Stealer will be just that grossly over prcied and I dont think they are JLR branded except when new in so i wouldnt waste your money the Exide is the OEM battery
Darn it, I put the car on my Ctek on AGM Recon mode for 2 days, and it showed the battery as full.
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 932 ![]() ![]() |
12.6v is about 95% charged. Stick it back on your ctek at normal charging, not recon
thanks, but this is the original battery (2015), so 7 years is about right to be needed a new one. --
I just replaced mine as most batts have a 5yr warranty and LR's you get about 3yrs its also worth looking at the the little battery too unless it a capacitor.
^ thanks, I thought as much about the BMS, so I plugged in my IID and cleared all faults.
is it the GAP IID as that has a dedicated BMS reset function built in? So the codes i dont think will make much difference. new battery is the best option to start with as its old and once they fall off they are hard to recover. Often if the lights were on and the battery has been flattened past 50% it can cause damage that even reconditioning canst fix so on an older battery its not worth bothering.
Oi vey, now I need a new back |
no worries chap a spa day sounds great! maybe somewhere like the Maldives would be ideal!
