![]() | Home > Technical > Global Open and Close |
| AndyCHO Member Since: 23 Dec 2021 Location: Wodonga Posts: 125
I was playing with suspension height changes today using the GAP IIDTOOL and decided to have a look through the CCF and noticed that Global Open / Close was not turned on..
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5155
You will no get the global closing to close the sunroof, L/R forgot to include the software in the system and never did a update so you can lock the car, arm the alarm and leave the sunroof wide open with no bleep or indication that it is open. However if you have the sunroof open switch the car off, climb out the window without opening the door then lock the car it will work. You may think I'm kidding but try it. Or open the window, leave the car running, get out of car and shut the door, lean through the window and switch the engine off and then try it, it will work and close the sunroof.
Posted this about 7 years ago.
OK... well that sorts the Sunroof part, now I just need to figure out the Drivers window.
So... other than the Sunroof the Global close issue is sorted.
| All times are GMT |
