Home > Maintenance & Modifications > Should an SVR have poly bushes?
Scrumpy
Hi all,
I have a 2016 SVR and my indy did a health check and said it had poly bushes fitted and that they shouldn't be on there.
Does it make any difference that it's an SVR or is it the normal pros and cons of poly against OEM?
I'm probably looking to get OEM put on when he does the arms, so any advice, greatly appreciated especially around the SVR bit.
Many thanks 2016 RRS SVR Estoril Blue
Post #623237 Wed Mar 30 2022 1:27pm
Goffy
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
All the advice I have received over the years is not to fit polybushes.
The main problem seems to be that they do not have an outer steel sleeve, so tend to enlarge the hole in the chassis or suspension component until it needs repair or replacement.
If they were really good, don't you think LR would fit them as original parts?
Post #623306 Sat Apr 02 2022 11:10am
Dave B
My 2010 model came to me with poly bushes.
Almost too stiff, but the worst is the squeaking noise when they are bone dry, almost embarrassing.
Wouldn't fit them myself, although have fitted poly bushed drop links to my D4 Commercial, and would fit these to my RRS if ever I needed to change them (again).
Dave 2010 3.6 TDV8 HSE (Gone)
2011 Discovery 4 Commercial SDV6 (Gone)
1980 OBLIC 4.0ltr Range Rover (went a long time ago)
Post #623308 Sat Apr 02 2022 11:59am
Buckster
There is only one make of poly bushes worth fitting and they are Superpros. Properly designed, engineered and tested to sort out Land Rovers design issues, which is why these vehicles eat through the standard OEM bushes so quickly. Performance very close to standard bushes in terms of ride quality also Wink 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #623317 Sat Apr 02 2022 9:31pm
