![]() | Home > General (L494) > SIDE STEPS |
| dazzerboy Member Since: 18 Sep 2009 Location: staffordshire Posts: 212
Turdmon if you call them and arrange to have them fitted for free actually cheaper £350 cash |
| Turdmon Member Since: 05 Aug 2020 Location: Lancashire Posts: 147
Nice mate. Thanks for that. I'll probably have a nip down the M6 then as it won't cost me £50 in diesel. |
| R4zb3rry Member Since: 28 Feb 2015 Location: Leicester Posts: 43
I’ve just purchased some sidesteps (not from sidesteps sadly as bought before seeing this thread) and they require cutting the plastic trim under the car - this isn’t an issue but, I am having serious issues with installing the nearside rear bracket as there are a couple of metal pipes (fuel) obstructing the threaded hole and I can seem to move them enough to locate the bracket. Has anyone (tyrefitter maybe?) come across this and resolved?
| Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677
Mmmm that’s the side where the fuel pipes run which you need to watch out when cutting plastic trim that you don’t catch a pipe but I’ve never come across where the bracket are close to the the pipes,,can you take a pic & post it.? Andy.
Hi Tyrefitter, thanks for the reply.
Hi,the only ones I’ve ever fitted are like the ones in the link below & never had any problems fitting.The brackets you have posted,I’ve never seen them befor.
Thanks, those are the brackets shown in the page of the item I purchased but, when they arrived they were the ones above.
Hi Tyrefitter, just for confirmation do you find that the rear brackets are usually a different design/shape between near and offside as I believe this is the issue with the set I have received, with them both being the same design there is no consideration of the brake/fuel lines on the nearside. Thanks |
Yes the rears are totally different for the reason of the fuel pipes.If you look at the 2nd & 4th bracket,you can see the difference for clearance of fuel pipes.
