Home > General > Oil in Air Filter - Turbo Gone?
neilneil2000
Hi all,
I recently bought a non-running 2007 RRS with the 3.6l TDV8 engine.
Only code is: P010C-21 (24) Mass or volume air flow B - circuit low - General signal failure -signal amplitude<minimum
Live values during attempted start below:
I have swapped the cables and sensors and the fault stays with the same intake pipe which indicates to me that the reading is valid and intake is blocked.
There is also oil in the air filter
My amateur diagnosis is telling me one of the turbo oil seals has failed and maybe seized.
Am I jumping to conclusions or do I need to get the wallet out?
Post #622971 Sun Mar 20 2022 10:36pm
Disco_Mikey
Wallet out. Turbo has failed. Smart money is on the LH turbo Thumbs Up
Post #622974 Sun Mar 20 2022 11:09pm
neilneil2000
Censored ! Thanks for the quick reply.
Any idea of the going rate at the moment? And are there any other tips/recommendations: new vs reconditioned, other bits to do at the same time?
Post #622975 Sun Mar 20 2022 11:16pm
If you're going to keep it, a new turbo. If it's a quick "fix and sell it on" then a re-con one, although that's potentially Censored for the guy who buys it down the line. 2012 SDV6 - it's missing a couple of cylinders
Post #622976 Mon Mar 21 2022 12:11am
neilneil2000
I pulled the top hoses off the intercooler today and it tries to start but won’t idle.
Could the engine be toast or is a blocked exhaust from the turbo failure more likely?
Post #623078 Thu Mar 24 2022 1:52pm
Disco_Mikey
Pull the bottom hoses off, see how much oil drains out
Post #623094 Thu Mar 24 2022 11:08pm
