Home > Technical > tdv8 rr sport zf gearbox
Mj1313
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
I have the dreaded gearbox issues. I have had the oil changed, properly with a machine. The filter wasn't changed they said i didn't really need to be changed Confused This was changed with DEXTRON 6 is this ok to put in these gearboxes? I have gear ratio faults and clutch solenoid off,seriously messes about. I can drive it as i have got used to it and drive around the faults when it starts working in manual mode the changes are perfect. Sometimes i have to switch off and switch on. I thought about getting a solenoid kit???? or do i just find a second hand box? apparently not the worse job to do??
Post #622802 Mon Mar 14 2022 9:19pm
Disco_Mikey
I can't find any reference to the ZF spec with any Dexron 6 compatible oils...
Did you have the issue before the oil change?
Post #622807 Mon Mar 14 2022 9:58pm
DirtBuddha
England 2010 Range Rover Sport TDV8 HSE Galway Green
Never understood why people change the oil and not the filter. What’s the use of that? It’s like having a shower then putting all your dirty clothes back on.
Post #622809 Mon Mar 14 2022 11:41pm
garrycol
Australia
The reason they do not change the filter is because the entire thing is of poor design - you have to remove the entire gearbox sump which may require the removal of a cross member and lifting the engine. Why they did not design the sump to allow the filter to be easily changed I do not know - designers should be required to work on items they design.
As a consequence the filter is often overlooked as it is just so hard to change. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #622812 Tue Mar 15 2022 1:10am
Disco_Mikey
Never understood why people would only replace less than half the oil... Wink
Post #622813 Tue Mar 15 2022 7:38am
LesW
France
I thought the trans fluid was Shell ATF. A Cheshire expat in France.
2015 RRS HSE 3.0 SDV6
2015 Aston Martin Vanquish
2010 Jaguar XFR Le Mans. Sold
Post #622816 Tue Mar 15 2022 9:25am
Disco_Mikey
Transfer case is manufactured by Shell, for JLR Thumbs Up
Genuine transmission oil is ZF
Post #622817 Tue Mar 15 2022 9:41am
The ZF gearbox is an "off the peg" item essentially. Its installation is down to LR.
However, in something like a gearbox where the servicing might only need to be done once or twice in the vehicle's lifetime, having to mess around a bit isn't that onerous if the compromise makes other aspects of the vehicle better.
It's more important to change the oil and thus the additives in the oil as they are the stuff that makes the gearbox work properly and also limit wear. Limited wear mean less stuff in the filter too. A full flush every 50-70k miles will probably do a lot to keep the gearbox healthy than changing the filter and 40% of the oil as in a "gearbox service".
It's possible to fit a different bottom plate to the gearbox - it has a slightly different internal design. This can be removed without messing around. I had this done on my old TDV8. 2012 SDV6 - it's missing a couple of cylinders
Post #622818 Tue Mar 15 2022 10:06am
Mj1313
The gearbox has slowly got worse, i bought the Zf long life oil and pan/filter conversion. But i then took it to a local Landrover place to have the oil changed via machine i asked them about the filter they were not convinced it would make a difference.
On the invoice it says 10ltrs of dextron 6 and some additive?
Ive seen somewhere they must have this long life stuff ????
Post #622822 Tue Mar 15 2022 10:55am
Advanced Factors
Site Sponsor
As far as I know:
The oil for a 6 speed is Lifeguard 6 TYK500050
The oil for an 8 Speed is Lifeguard 8 LR023288
Neither of these is DEXRON 6 and I was not aware that it was compatible. Maybe the LR specialist has some evidence to show that it meets the same specification. Paul Redding
+44 (0)23 8052 2776
paul@advancedfactors.co.uk
Post #622824 Tue Mar 15 2022 12:19pm
Why didn't you ask them to use the oil you'd spent money on?
And Dexron 6 and an additive? I'd be asking them what exactly they've put in your gearbox. I wonder if the additive is just a tube of Dr Tranny.
Sounds like you need to get them to do the job with the correct oil. 2012 SDV6 - it's missing a couple of cylinders
Post #622826 Tue Mar 15 2022 12:54pm
