Home > Maintenance & Modifications > Radiator - WOW Whats happened here
Lynchy
United Kingdom 2007 Range Rover Sport Supercharged HST Java Black
As the title suggests. Ive just fixed my sporadic alarm replacing the Bonnet Latch and Sensor, only to notice this as i was doing it !!!
Post #622451 Fri Mar 04 2022 7:29pm
Lynchy
Anybody got any idea whats happened here, or what my risks are?
Post #622452 Fri Mar 04 2022 7:30pm
Stevepd
Wow, I’ve never seen or heard of anything like that. Shocked 2006 2.7 TDV6 HSE in Cairns Blue.
Post #622455 Fri Mar 04 2022 9:32pm
Farmer Chalk
Whatever’s happened that radiator needs replacing urgently! By all counts it’s also a git of a job!
Post #622458 Sat Mar 05 2022 12:27am
Probably 3 rads.
Is it the front one ?
Post #622461 Sat Mar 05 2022 9:32am
Lynchy
No its not the front 1, but the biggest 1, directly behind the front 1.
Post #622464 Sat Mar 05 2022 10:14am
some useful info here about ordering rads.
https://www.rrsport.co.uk/forum/topic58549...t=radiator
Make sure there is enough Anti Freeze in it,
Post #622467 Sat Mar 05 2022 1:11pm
Lynchy
Cheers Andy. Any idea how this could of happened? And what Rad is this? Air Con?
Post #622469 Sat Mar 05 2022 1:43pm
It’s the coolant rad.
I was wondering if insufficient Anti freeze could have caused it. But probably not
Does you air con work ?
Post #622473 Sat Mar 05 2022 4:42pm
Lynchy
Air on works. But I think this has only just happened since I switched to ECON. I’m almost sure of it.
Post #622477 Sat Mar 05 2022 6:32pm
The air con rad slots/mounts on your faulty coolant rad.
I tend to use some long cable ties, linked together to make longer, to secure the air con rad to the top slam panel loosely.
You then unslot it from the coolant rad, and remove coolant rad.
The biggest difficulty is removing the fan.
Need special fan tools
Post #622478 Sat Mar 05 2022 7:25pm
Lynchy
Cheers for all the info and help Andy. Think this one might be a Land Rover Specialist job . . .
Post #622479 Sat Mar 05 2022 7:40pm
Lynchy
Ive had my mechanic looking at this today, but hes never seen this before. Hes no Land Rover Specialist mind, but has never seen it on other vehicles either !!!
Post #622617 Tue Mar 08 2022 9:00pm
Lynchy
So today was a little worrying. A very small LRS looked at the Rad today. Never seen anything like it before. I know it needs replaced, just wondering how long its been like that now . . . Going to take it to Les Potts in Sunderland (big LRS). See what they say.
Post #622650 Wed Mar 09 2022 7:15pm
