![]() | Home > General > Reliability? |
Teksabb Member Since: 27 Dec 2021 Location: Cheshire Posts: 4 ![]() ![]() |
Hi guys,
Three-Six Charlie Member Since: 21 Mar 2019 Location: Wigan Posts: 63 ![]() ![]() |
I've had my 2013 L494 5ltr example for three years now. Zero faults. 2013 L494 5.0 SC in Chile Red |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 927 ![]() ![]() |
From your other posts, you seem to be buying new, so 3 years warranty & you will get a loan car if it needs anything. When I ordered mine I also took out the 5 year service plan which was a good deal then. Don't know about now. Plug in hybrids, can't comment about. Only problem I ever had was that the rear brake callipers shed the red paint, but were replaced twice under warranty, no questions asked. Oh I also had a parasitic drain which meant I kept getting a low battery warning. Main dealer was useless "drive it more" was their solution. Auto electrician did a fault find & fixed it.
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 405 ![]() ![]() ![]() |
I have owned my 2010 TDV8 since new (over 11 years) and the only expense on repairs that I have had is replacement of the alternator. I had quite a few problems in the early years but Landrover covered all those items. Most of these early problems were because the dealership had a lack of knowledge about the vehicle. |
2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 217 ![]() ![]() ![]() |
L494 SDV6 Dynamic MY 14.5, just hit 230K (miles) In this time it has needed: - Alternator Inlet Manifolds n/s (but also replaced o/s as preventative measure) Arc Pipe (flexible section from pump) Earth Stud replacement on o/s/f (did n/s/f as preventative measure) Obviously it has gone through many sets of discs, pads and tyres and regular servicing. All servicing & repairs done by me & agree with all the other posts, do not use a LR Main Dealer! My old L320 now has 417K miles on it and still going strong - look it up - Reg FM07 KMX |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9078 ![]() ![]() ![]() |
417k and 230k miles? Now if anyone wants evidence that the things aren't inherently unreliable, that should do it.
DirtyApe4x4 Member Since: 06 Jun 2020 Location: Dayton, Ohio Posts: 25 ![]() ![]() ![]() |
2011 (U.S.) GT LTD ED at 135.000 miles and all original except a few coolant hoses, the alternator which I just replaced and the known issue of timing chain guides on the 5.0 petrol. 2011 Range Rover Sport GT Limited Edition/Santorini Black 5.0 Liter
