![]() | Home > Maintenance & Modifications > Full hatch on L320 won’t go down |
Silverstone Member Since: 04 Sep 2014 Location: Towcester Posts: 184 ![]() ![]() ![]() |
Had the same happen with mine last week on my MY2013. Managed to get tailgate open and then applied lots of WD40 and worked it into the latch in the tailgate. Fine ever since. There is no replacement for displacement - W O Bentley
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5131 ![]() ![]() ![]() |
If it's a powered tailgate it won't power down on it's own anyway off the key or interior switch if I remember right, unless it has had the "power close mod" fitted. Just wondered if it has if that was playing up.
ed7dohc Member Since: 19 Feb 2017 Location: Belfast Posts: 11 ![]() ![]() |
Hi my tail gate opens ok just won’t lift up on its own ( intermittently) ALthough stays up if I lift it manually . But there’s a button my tail gate for closing nothing happens now when I press it to close . |
No but I’d like to get the mod . As I said the lock releases ok but for some reason won’t always go up on its own with out me giving it some help and I have to manually put it down ![]() |
Mine did something similar at one point and would only release but a second push of the switch and it went up, closed ok from the tailgate switch though, It did only seem to do it when ambient temp was high which probably isn't the case over there at the moment. I did however replace the switch that fit's between the rear number plate lights and it has been fine ever since and that was a few years ago now. Also have the power close mod fitted.
I’m leaving it into a lot specialist on the 28th but I’ll continue my search until then .. I’ll update the post if and when I get a fix |
