![]() | Home > Maintenance & Modifications > Stuck Bonnet |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 508 ![]() ![]() ![]() |
Have you tried pulling the handle then giving the hood a quick whack with your hand? Just a quick hit over the latch with the base of a closed fist. Obviously not so hard you do damage to the car or yourself, but just enough to jar it. You may need somebody to pull the handle at the same time. It’s a little bit of an art. If it gets it open, I suggest closing the hood like you mean it. It’s not the tailgate, there’s no soft close latch. Although, make sure there’s nothing obstructing it from latching. I left the cap from a washer fluid bottle on the radiator support, wouldn’t latch. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 225 ![]() ![]() ![]() |
I had the same with mine got my neighbour to push down on the bonnet while I pulled the lever took about 3 attempts & it opened, gave everything I could get to a good clean & lubrication and its been fine since. |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 932 ![]() ![]() |
As "Boxers" said someone to press down & release at the same time Range Rover Sport (gone): Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S: Range Rover Fifty P400e |
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 ![]() ![]() |
Thanks all.
Ok Tried the above , It isnt opening still.
woodsie Member Since: 23 Nov 2015 Location: Milton Keynes Posts: 67 ![]() ![]() ![]() |
On mine, late 2010, the cable is in 2 pieces. Cable from the handle goes to the near side wing, I think behind the plastic inner wing cover and I think quite high up and near the front.
