![]() | Home > Technical > Electronic handbrake fault (not engaging) |
| MallorcaNick Member Since: 03 Jan 2021 Location: Mallorca Posts: 50
Can't anyone help please??? |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
It probably needs to have the codes read to make sure there's no pointers there to start with. Otherwise, if it's not applying at all, it's either the EPB module itself or switch/wiring to it. I wonder if a fully seized actuator on one wheel would prevent the whole thing from working or whether it's designed to allow the other one still to work.
| Ezituper Member Since: 10 Dec 2016 Location: Herts Posts: 71
I can’t remeber the symptoms, but I never used my park brake, had an issue and removed the drums. The friction material had separated from the shoes, took ages to clean out, new shoes and all was fine. |
The mechanic told me last week that it's the EPB module that needs changing. Is than an expensive and difficult fix??? |
| Advanced Factors Site Sponsor Member Since: 26 Apr 2013 Location: Southampton Posts: 289
For AA000001 (2010) onwards the parking brake module is LR072318
| All times are GMT |
