Home > General > DSC/ABS HELP
TONY173
England 2010 Range Rover Sport TDV8 Autobiography Santorini Black
DSC/ABS HELP
DSC/ABS ,
Hi all I have only owned my 2010 tdv8 RRS for a couple weeks and I have a problem with the dsc light coming on and activating the rear n/s brake when turning right, it doesn’t happen turning left. The car was well looked after and came with fsh, the previous owner said he had had now problem with this. The car was stored off road for about 12mths as he had got a new one.
Please can anyone help , I feel it may only be something simple and don’t want to spend £s if I can fix myself, I’m no mechanic but not completely useless
Thanks in advance, Tony
Post #621114 Wed Jan 19 2022 9:19pm
Any mis-matched tyre tread depths, I believe they may cause something like this if vastly different depths.
Post #621115 Wed Jan 19 2022 9:35pm
TONY173
All tyres was replaced I’m told 4000 miles ago and all have good tread about the same, I did check Tyre pressures and they was low, I have topped up the pressures but made no difference
Post #621116 Wed Jan 19 2022 9:44pm
If parked up for 12 months, might be worth just checking to see if you have a sticky brake caliper or guide pins. Could read this may help or give a clue.
https://www.rrsport.co.uk/forum/topic57360...=dsc+light
Post #621117 Wed Jan 19 2022 9:54pm
TONY173
Thank you
Post #621118 Wed Jan 19 2022 10:02pm
garrycol
Australia
Does the problem occur with DSC turned off? A way to check whether it is DSC causing it or something else. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #621120 Thu Jan 20 2022 12:26am
TONY173
Don’t know I will try it
Post #621132 Thu Jan 20 2022 5:29pm
TONY173
No problem not there when dsc turned off, I have cleaned all sensors, calipers and greased guide pins, also checked Tyre pressures which was a bit low on the rear n/s. Still got problem but not as bad
Post #621271 Tue Jan 25 2022 7:17pm
Have you had the codes read to see if there are any showing? might give a clue.
Post #621274 Tue Jan 25 2022 8:18pm
