![]() | Home > Tips & Tricks > ACE Filter replacement |
| Iomegas Member Since: 16 Nov 2020 Location: Newcastle Upon Tyne Posts: 217
Hi Kev thanks for vid link have you changed your filter ? |
Cherrz Kev have ordered filter I was just worried about some articles I noticed saying the threads broke up in housing when you removed the plug sometimes. |
| Supermondo Member Since: 08 Aug 2021 Location: Milton Keynes Posts: 1
Hi guys, does anyone know what size socket is required for the filter plug? |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5153
38mm
| DirtBuddha Member Since: 12 Jan 2022 Location: West Sussex Posts: 32
Where do you guys buy the filter and fluid from... LR Dealers (hopefully not at their prices)? |
| knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139
Fluid from here: https://www.smithandallan.com/products/tra...over-ace-/
Cheers! |
So how do people drain/replenish the ACE fluid?
Drain it out with a little 12v pump. Kev
How much do you take out at a time though? And won't that introduce air into the system?
You can change it from below through disconnecting the lines to the ARBs. That could introduce air into the system and is more of a pain to do on the driveway.
No mention of having to use a computer in the manual, you bleed it using the same principle of pressure bleeding a brake system, unfortunately you do need one of these special tools 204-591-02 (£400.00 from L/R so no surprise there then) to open the solenoids to allow the fluid through to the bleed screws, unless you could improvise one without to much difficulty just need to energise the solenoids with live feed to open them. As said not sure it would be very easy without a pit or ramp.
| Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 427
I empty the reservoir using a syringe and short length of hose and refill it several times running the engine for several minutes inbetween refills (to circulate fluid) at every engine oil change.
