Home > Maintenance & Modifications > Fuel Cooler for Starter Removal |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4798 |
I don’t recall it being difficult.
Sat Jan 15 2022 9:25pm |
jp1 Member Since: 24 Jan 2020 Location: Cornwall Posts: 12 |
Ok thanks, managed to get to it this morning, had to remove the aluminium shield under the driver wheel arch so i could get a 10mm ratchet spanner from above and it came free. As you say, i did end up hugging the underside!
Sun Jan 16 2022 11:07am |
Black pipes are fuel pipes
Sun Jan 16 2022 11:37am |
Managed to wiggle it out and i can see why the comments on undoing the +ve cable, thanks for your support.
Sun Jan 16 2022 9:40pm |
Jack handle to undo crank bolt ? |
Sun Jan 16 2022 9:45pm |
sorry i should have said Trolly Jack...essentially take the top piece and put it over the 2ft break bar to get me the leverage.....i had no chance without it. Worked great for me on undo and also the +90 degrees stretch on tightening |
Sun Jan 16 2022 10:04pm |
https://disco3.co.uk/forum/oil-pump-change...57644.html |
Sun Jan 16 2022 10:07pm |
Just remembered.
Mon Jan 17 2022 8:13am |
